Centering tool? Knuckle rebuild
RevISK
sunset valley, tx
Hey hey,
Doing a knuckle rebuild on this fj62 and need/want to double check the ahim Placement. It only had one shim on the bottom and more importantly, the bottom bearing fell out in all its individual pieces when I removed the shaft.
This leads me to believe the spacing was willy nilly. Someone definitely got in there at some point earlier in time as evidenced by the copious amounts of RTV used in assembly.
Does anyone have a centering tool I could borrow/rent this week? Barring that, any suggestions to do it sans said tool?
Thanks,
Ian
Hey hey,
Thanks,
Ian
Hey @RevISK , have done the knuckle rebuild yet? I am currently doing the same on my 40 build and would like to help/observe (if you don’t mind) while you are doing so I can do mine correctly. I disassembled mine on Friday and top/bottom bolts were not tight and both sides only has shims on top.
Thanks,
Luis
Thanks,
Luis
I’ve done the Passenger side of the 62 and will attack the DS of the 62 and all of the 40 when I return from this work trip this coming weekend.
I spent far too much time cleaning crap off of the outside of the whole assembly so I got less dumb and took it to a car wash and spent 3 cycles spraying off everything I could.
PM me and perhaps we can arrange a time for you to come over. It’s not hard, just filthy. I did spend a significant amount of time waiting for parts I didn’t think I’d need.
Ian
Ian
Thanks Ian, it looked simple enough after watching a couple of how to videos….main concern is also shim placement & knuckle centering as well. As mentioned before, I’ve already disassembled and cleaned everything but when I disassembled, nuts were not too tight and both sides only had shims (2ea) on top. I got the axles from a ‘76 for disc brakes and not sure what the previous owner had done to it.
