center diff lock switch
Is the center Diff lock switch(on the dash) from a 91 going to be the same/work in a 94 for the diff lock switch, 7 pin mod .
Thanks
S
nakman said:
Are you asking if the switch from a 91 will fit a 94, or are you asking if the pin7 mod will work in a 91 or 94?
Sorry I was asking if the switches were interchangable, I thought I had access to a doner rig.
I would delete this one if I new how.
S
I think the swith from a 91 will work on all the non air bag models...so 91-94 should all be interchangeable.
91-94 are the same, rounded top, switch. 95-97 is the flat, rectangular, switch.
Seriously? Would anybody on this board play Trivial Pursuit with this man. :flipoff2:
Much less hang out with him. :D
Precisely why I drink Keystone. If I had good stuff everybody would be over on my porch consuming all of it.....:flipoff2:
Ok. Ok. your a fart smeller. Now stop rubbin it in.................. :flipoff2:
Hey I want my opener back! :mad:
reffug said:
Seriously? Would anybody on this board play Trivial Pursuit with this man...
I'd sit down for a round of Trivial Pursuit...as long as it's not the Toyota-lovers version :flipoff2:
You sir are a scoundrel of the first order, and have my respect............. :flipoff2:
Chicken...............:flipoff2:
how abotu a game with the Warmonger's Edition :D
I'm all over that one.....:D
Q:
What was the fix for the "7th round stoppage" in early production M1 rifles?
jjbodean1970 said:
weld the receiver?
On the right track there.............Where?
The forward vertical guide rail on the LH forward receiver leg had the top nipped off by the tooling that threaded the receiver to accept the barrel. This did not happen to the 80, hand assembled, "model shop" rifles. The early production tooling was the culprit. The resultant "nip" caused the 7th round (of a clip with the top round loaded on the RH side only) to jamb. Clips loaded with the top round on the left did not have a problem. By re welding and grinding the rail the problem was solved.
Actually you did quite well for such an obscure question.
