Center Arm Bracket Assembly (1 Viewer)
Chesapeake, VA
Well this is this newbies first technical question.
I was doing a tune up and a close inspection of my newly aquired Cruiser and was investigating the source of sloppyness in my stearing. I think the trouble is in my Center Arm Bracket Assembly. When I have my son wigle the steering wheel back and forth the first place I can see any real sloppyness along the steering linkage is there.
I have greased the assembly and made sure that the the top and bottom nuts are tight. I have not tried to tighten large threaded cap as it was very tight and I wanted to get some advice from the forum before I went much further.
Thanks in advance for any input.
cruiser_guy
Good morning from here, Just finished updating ou
Wherever the truck stops!!
Website
wirrell.com
I'm in the process of doing the same on the '76 FJ55. I hope you have an easier time than I do in dis-assembly!
Get the rebuild kit as it has everything but the housing and center arm.
cruiser_guy
Website
wirrell.com
Where did you get the rebuild kit?
www.sor.com but there are others around that sell it. I just happened to be there getting other stuff as I was passing through to Guatemala from Canada with the 'FJ55.
Chesapeake, VA
Canada to Guatemala now that is a long drive.
cruiser_guy
Website
wirrell.com
Chesapeake, VA
you forgot the link. I would like to see the pictures. I bit it has been a interesting trip.
