Catalytic converter gasket leak - look at this mess I'm about to tackle!
Finally Finished
I finished this morning. Thanks for all the help. I cut between the flanges on a couple and the bolts at the end. I used a corded recipricating saw. Only one blade needed. It also took a lot of hammering the get the bolts popped out after they were cut. If I had to do it again, it would take a lot less time.
That link that was posted earlier showing options for the single replacement cat has a number of versions on the page. Was there one in particular that I should look to? Plus, are we talking about cutting the down pipe just after the first O2 Sensor bung and having to weld an extension tube from the muffler down pipe's flange forward to reach the new, yet shorter length cat?
Could anyone out there provide some specific info on which single cat replacement model they've used (and subsequent experience with it, if possible)?
Thanks!
No fist hand experience, but reading on 'mud this one has been used: Magnaflow 99006HM
Thanks, retro!!
I'll check it out, as well as do some more searching to see if anyone's posted pics on a swapout. I'm curious if they cut the original downpipe just after the front O2 sensor, but still had enough pipe to weld the Magnaflow to it.
Well I'm finally revisiting this issue. Yup after all this time, I still have the OEM cats in there with a leak b/w Cat 1 & Cat 2 (flanges are too deformed to get a clean mating surface), and now also found a small rusted hole in front of Cat 2. Awesome!!
So, I've got an 800+ roadtrip this weekend and ran out of time to do the cut-n-swap project. Looks like I'll be slathering JB Weld in those 2 locations and letting it sit overnight. Should help by the time i set off early in the AM.
I've called around and although there aren't many mom&pop muffler shops in NoVA, I did find one in Vienna that's intrigued by the project. Really no way to know what the fabrication/installation cost will be until I show up at the shop with the materials in hand for him to look at and inspect the OEM pipes he'll have to weld to.
The issue at hand is 2-fold: 1) Decide which Magnaflow cat model to purchase; and 2) A concern I have about the weld locations.
1) I've boiled the model choices down to either the High-Flow Spun version (#59906 2.5ID Offset/Offset design, or the #59956 2.5in/out Center/Center), or the 16" long Heavy Duty "heavy metal" model
Between the 2 Spun models, I think the Offset #59906 version will tuck up better . I'd like to hear any actual experiences with either of these models.
2) When I inspected the locations where the cats would be cut away, it was a bit startling to see that there was MAYBE about 1/2" of pipe left until making contact with the O2 bungs. Is that going to be enough space of pipe material to get a good weld without having to purchase new bung mounts from Slee?
Thanks for the input.
just know you can get some exhaust goop stuff that is like JB weld but for exhausts. I've used it to plug a hole or two. Just gotta give it a little time to set up.
