I was wondering if someone could help me out. I have a 1972 FJ40 that has some steering issues. It has an extended shackle lift on some old springs with 4 degree shims in the spring perches and it follows every little rut in the road.
I took it to an alignment shop and they told me my caster is at -2.95 degrees on the left front and -2.79 degrees on the right front.
I have been researching caster angles here on Mud and it looks like I'm suppose to be at +1 degrees.
I took the cruiser to 4 Wheel parts to see what I can do to fix the wandering problem. They told me that my caster is fine at -3 degrees and to not rotate it to +1. They said rotating it to +1 degree would make the steering worse. I'm confused!
Thinking about my -3 degree caster to me makes sense to rotate my axil back to where it is at +1 degrees. I feel like I'm being pushed into every rut as I'm going down the road, but if I do that I would have to take the existing 4 degree shims off and replace them with 8 degree shims.
6 degrees won't be enough to bring me to +1.
I fear that 8 degree shims may rotate my axil so much that I may run into drive shaft issues. Is this true?
Any insight would be most appreciated!
Dutchman
Dutchman
