I've noticed after driving the pig over the weekend, especially at higher speeds, how sensitive the steering is. It dawned on me that when I had the alignment checked, they also checked the caster angle. I went back and looked at the print out: -1.6 degree on left front and -2 degree right front.
I have OME springs with no shims. 33" tires. Questions:
!. Do I buy 3 degree shims?
2. Should I buy two different degree shims to compensate for the different caster angle readings?
3. Should I buy 4 degree shims ( as suggested by Bryce at Cruiser Outfitters, due to the larger tire size
that I'm currently running with)?
Any help would be appreciated, thanks
