Cargo area floor covering options
Nelson, BC, Canada
Im am going to be removing the factory carpet from the floor of the cargo area in my 85 BJ60. Im doing this because I struggle to keep it clean/dry. I often sleep in it when im camping so im always avoiding hauling things around that may or may not get the cargo area carpet dirty; such as my dog. I was thinking I would spray the metal floor with a spray on box liner material, which would be ideal and easy cleaning and keep the floor dry.
What would you guy do or what have you done? Is there a vinyl option that can be ordered somewhere?
There are as many options here as there are tire choices, I have duraback smooth paint , sound deadining paint(second skin) heat insulation and 1/2 inch closed cell foam with the liner that Specter Off Road(black rubber with the diamond pattern) on top of that but then I am crazy. Again do what you need to be comfortable back there and keep it clean as well. Post up some pic's of what ever you decide, someone will learn from it. :D
I used double sided insulation that was passed on too me from a fellow Mudder. Easy to work with and great sound deadening qualities. The floor mat is a 3/4 gym flooring mat. You can also use a horse stall mat from Tractor Supply Co.
Easy to maintain and the Lab loves it! :D
I have had the aforementioned tractor supply horse stall mat for a year and it has worked out very well.
In my first 60 that went wheels up (sniff), I put down some extra Pergo (vinyl wooden flooring) that I had lying around that looked great and worked surprisingly well. My present rig got the carpet torn out and Hurculiner applied. I would recommend both.
Stall mat, this is only 3/8s I believe. They also have 1/2" and 1/4" cut to length. I love it, Mine has no smell whatsoever bought from Dels farm supply.
This is what I want!!!!!
I did the same thing except I got my piece from the old weight room. I took the carpet out, traced around it onto the ruber and cut it with a jig saw.
I'm looking for options for my 55. I really like the stall mat idea. How did you guys fasten it, to the tailgate.
Thanks, Ron
