- Joined
- Jun 3, 2012
- Threads
- 10
- Messages
- 23
Hey Guys, I recently had my truck engine swapped and re-sealed by Ryan Baxom out of Warrenton, Va. He did a great job and I was pleased with the work. I picked up the truck in January and drove it with a buddy down to Nashville (my new home). About 2 hours outside of Nashville, right after filling up the tank with gas, it randomly stopped died on me and I had to pull over. The engine would turn but it was not receiving any fuel.
I had the truck towed back to Nashville and I started working with a retired Toyota mechanic down here, Charles Trueblood. Since my truck stopped working shortly after filling up on gas, he was convinced that I received bad gas and that it had a bunch of water in it. I will spare you the amount of times I picked up my truck only to drive it less than 2 miles and for it to break down again. Here is what we have done:
We:
1.) drained the tank and filled with good gas.
2.) Changed the spark plugs (mechanic said water in the fuel caused the plugs to go bad),
3.) Got a new pump and filter
4.) Dropped the gas tank and cleaned all rust out of the gas tank (common problem for rust to occur in these trucks)
5.) Replaced all the fuel lines
I drove the truck to get coffee this morning after my mechanic had been working on it since 9 PM last night. Drove like a DREAM on the way there. Got coffee and started heading home and it started choking and sputtering. It would kick in and drive fine for 200 yards and then back to sputtering. Barely made it home.
I called Charles and he said he thinks the fuel pump and filter are bad due to junk being in there from the rust in my tank. Something tells me I will still have the same problem if we do change out the pump and filter.
Anyone have any ideas of what could be wrong???
It is driving me nuts as this car should be driving close to perfect.
We:
