Can't find a oil reg.gasket-help needed!
Santa Cruz Mountains,CA. TLCA#7702
Hi all,I am having no luck in finding a gasket for my oil pressure regulator.Any ideas? What can I use to make one?
Thanks,John
Go to any parts store and ask for a sheet of gasket making material. In a pinch a piece of a file folder, a piece of construction paper, a piece of a cereal box or any thin paper sheet material will work. Apply a THIN coat of silicone to each side, let it set up a bit then bolt it in. IF the mating surfaces are in good shape, Ultra Gray silicone gasket maker will work with no gasket at all.
Thanks guys,I will try some of the ideas.Just put fresh oil in too,going to have to drain and save it! I had oil gushing out of the oil pressure reg. damm. "F" engines,I should have gone with a 2F! Oh well next build up,this the get it up and running one.
Thanks,John
Thanks,John
That's no reason to give up on the mighty F engine!
Thanks for your order.;)
