Can I use Delo 400 LE 15w40 in my 2F?
So here is a question for the group. When I got BeBe the guy had no maintenance history really on it, a few scribbled OCIs and that was about it. I changed the oil with a good 5w30 in February and when I pull the dipstick it is just starting to change from that nice "new oil" light amber to a little darker honey color. I have been considering changing the oil again in a fairly quick OCI, I have maybe 1000 miles on the oil, to see if I have anything funky in my oil (the old stuff had been in there for quite a while). Plus I want to change to something heavier as I know that I don't need the 5w30.
It may get cold where you are, but I wouldn't run a 5-30. If you need that in winter, Rotella T6 semi syn + additive. 5w-40 synth. 22 bones at Wallyworld.
:steer:
I have a thread on oils attached below. You can use the Delo 400LE, however, it would be best to use the Delo 400 Multigrade 15W40. The LE (Low Emissions) is formulated to meet the 2007 and later diesel grade oil requirements. The Zinc and other friction modifiers have been removed or decreased to less than 400 ppm. The Multigrade still has 1600 ppm of Zinc which is essential for flat lifter camshaft style engines to have a long life.
The Delo 400 MG is harder to find but it is available. If you can't find it Pennzoil has a 25W50 Racing Oil labeled for off road use only with 2000 PPM of Zinc. It has a gray label.
If that fails use an additive like ZDDP or Comp Cams break in lube.
https://forum.ih8mud.com/60-series-wagons/480074-oil-you-using.html
Caterpillar shops still sell CAT DEO 15-40 (not the ULS oil) that is CI-4 rated and does not need the ZDDP additive. Its around $17 a gallon.
One vote for the Mobil 1 15w-50:cheers:
Phosphorus is the additive you should really key in for the flat tappet wear reduction http://www.mobiloil.com/USA-English/MotorOil/Car_Care/AskMobil/Zinc_Levels_15W50_Mobil_1_Products.aspx
Mobil 1 has a nice 15w-50 for sale at your local walmart ~$25 for 5qt jug.
This is the best oil you can run for the money. Plus you don't have to change it as often because it is more heat shear resistent compared to a dino oil.
I put it in my 40 and it seems to run a really good oil pressure, plus I know it is cleaning out a really dirty engine I inherited from the PO.
Phosphorus is the additive you should really key in for the flat tappet wear reduction http://www.mobiloil.com/USA-English...Mobil/Zinc_Levels_15W50_Mobil_1_Products.aspx
I run the 15w-50 Mobil 1 in my rig, used to have to buy the single quarts but just saw that Walmart is now selling it in the 5 quart jug. Pretty solid deal
Damn I may actually have to break my rule and streak for that. Really REALLY HATE WalMart but that is almost to good a deal to pass up.
When I changed my oil a week ago, I found Mobil Delvac 1300 Super 15W-40 at Pep Boys for a shelf price of either 17.99 or 18.99 and they had a 5.00 mail in rebate per one gallon jug. Called Napa, they had the oil for a comparable price but hadn't heard of the mail in rebate. I went there anyway to get the Napa Gold oil filter. Still made by Wix.
I just purchased 3 quarts of Z-Rod for my Karmann Ghia...$30.00 bucks! I wish I could afford it for the 2F!
Zack
Sorry to raise an old thread but I've been researching this same topic and before I settle in on an oil brand I was hoping to clarify this point. In another thread someone points to this independent May 2013 analysis of Chevron Delo 400LE:
http://www.pqiamerica.com/May 2013/chevrondelo.htm
which shows that modern 400LE has nearly 1500 ppm zinc, highest of any in the 15w40 class evaluated.
Do you guys still think it needs an additive? I'm a newb so I'll defer to experience/reason but this seems pretty convincing.
:cheers:
Sorry to raise an old thread but I've been researching this same topic and before I settle in on an oil brand I was hoping to clarify this point. In another thread someone points to this independent May 2013 analysis of Chevron Delo 400LE: http://www.pqiamerica.com/May%202013/chevrondelo.htm which shows that modern 400LE has nearly 1500 ppm zinc, highest of any in the 15w40 class evaluated. Do you guys still think it needs an additive? I'm a newb so I'll defer to experience/reason but this seems pretty convincing. :cheers:
Use it and don't look back.
Unless they have changed something recently every Blackstone that I have found on the web about the 400LE has shown the ZDDP in the 800-900 range. If this is true it is definitely a good buy as you can pick up a 3 gallon pack from Costco for like $28.
Well I hope they changed the formulation, because if so off to Costco I go.....
That would be great news, I could even run that oil in the Karmann Ghia.
Zack
Every VOA I've seen for the Delo LE 15w40 had been under 1200ppm. I don't trust the study cited above. The Delo 15w40 Multigrade, yes... I think they fawked up the samples.
If the zinc conc of 1500ppm was verified, I'd use it in a heartbeat without additional zddp additive.
Uh oh!
I just changed the oil on my fj62 and after reading through all the threads I came to the conclusion that Chevron Delo 15 40 LE was the way to go so that's what I used.
Do I need to drain that and put something els win it?
As long as you put a quality oil in it, I wouldn't worry about it. Add a bottle of ZDDP additive if it makes you feel better about it.
Thanks to everyone weighing in with doubts. I've sent an email out to the owner of this study questioning its validity, I'll report back on what he says.
Awesome. :beer:
Here is the reply I got from the Petroleum Quality Institute of America:
"Thank you for your email on our analysis of Chevron Delo 400LE engine oil. The testing laboratory PQIA utilizes is accredited to ISO 17025 A2LA, the highest level of quality attainable by a testing laboratory, and we recheck any results that appear inconsistent. In this case, the zinc and phosphorus results are in the correct ratio and we had no reason to suspect any laboratory errors.
While it is not uncommon for different laboratories to give different metal test results, the differences you noted are more than we would expect. Chevron's Product Data Sheet for this product shows typical zinc and phosphorus levels of 0.13% and 0.12% respectively, which are right between the results you have seen and those from PQIA. We have no way of knowing whether Chevron may have changed the formulation and suggest you contact them directly to determine the correct typical levels for these elements.
Thanks again for your interest in oil quality!
Tom Glenn
President
Petroleum Quality Institute of America"
Here is the PDS he references: https://cglapps.chevron.com/msdspds/PDSDetailPage.aspx?docDataId=339444&docFormat=PDF
