Have been having the out of phase/balance issue on my front driveshaft, removed it to test if it was only the front, and got no vibrations. Am wondering if I would be able to do a roadtrip of around 800 miles all highway.
I just recently did this when I blew a u-joint on a trip. Worked fine for hundreds of miles. CDL locked.Lock the center diff and drive. Will not harm anything with the center diff locked.
It’s full time. You may need to trick the transfer into locked HI range.Since I don’t have the triple locker, isn’t mine already locked as “full time AWD?”
To be very clear: if you don't have the center diff lock switch (on the dash above the climate controls), the center diff isn't locked when in high range (it automatically locks in low range in factory configuration). You should have the center diff locked for your trip. Adding the switch is a 10 minute plug-n-play project that any 80 should have. The boys at Cruiser Outfitters or Valley Hybrids can set you up. Read here on 'mud on how to install.
Thanks, it looks like I don't have that switch installed, but I find it odd that I was able to drive today with just the rear DS.
No. You have a viscous coupler in your transfer case. You're able to drive around town for testing a little because it is sending torque to the front axle since it sees the rear slipping because there is no rear drive shaft. If I remember right, doing that on a long drive can cook the VC. The center diff has an actuator that locks it when you shift into low range, or when told to for those of us with the switch. To do what you want to do, shift into low range and let the center lock, then pull the fuse. Then you can shift back into high range and the center diff will remain locked until you put the fuse backSince I don’t have the triple locker, isn’t mine already locked as “full time AWD?”
You have a lot of reading to do I think. As in reading various faqs and tech sources, not just asking questions and chatting in the forums.Since I don’t have the triple locker, isn’t mine already locked as “full time AWD?”
Yep, that's definitely true. And I think part of my format for learning is through chatting, so kudos to the kind individuals who take the time to answer beaten down horse questions.You have a lot of reading to do I think. As in reading various faqs and tech sources, not just asking questions and chatting in the forums.
In a pinch, the hazard switch will work as the CDL as well.....If you don't have the CDL switch, read up on the forum about locking the CDL by putting the vehicle into low range and removing a fuse. You will need to do this to drive without the front driveshaft.
I HATE the term Triple locked! Makes my skin crawl!There ain't no such thing as a "triple locker". "Triple locked" is a slightly misleading phrase that has kinda blossomed in the forums.
All full time 4 wheel drive rigs have a center diff. And they all have the capability to lock that center diff. They are all "single locked" if you will. Guys just think that it sounds cooler to say "triple locked" than saying "I have the locking axle differentials". I guess.
TP? lol!I HATE the term Triple locked! Makes my skin crawl!
as someone who rocks "TRPLOK" on my plates this made me chuckleI HATE the term Triple locked! Makes my skin crawl!
