I drove 44 about 165 miles yesterday... All but 8 miles on pavement... Generally around 60-65 on the highway... Occasionally, up to 75, while passing.
This morning, I find thick, black blobs under the rear end.. From shock mount to shock mount.
The rear end, itself, was glistening, from the horizontal welded seam to the bottom, only on the front side. The bottom three nuts (front) on the pumpkin were also glistening.
The rear driveshaft was dry... As are the two rear wheels.
I checked the diff... It's properly full of clean gear oil.
I cleaned the mess off the rear end and found the two bottom-left-most nuts slightly loose. I re-snugged them and jacked the rear up and put it on stands... Then, I started 44 and went thru all four gears several times.
No obvious leaks...
No noise, no problems that I'm aware of... Just the obvious shine and the blobs on the floor...
Can anyone look at this pic (sorry, best I could get) and tell me where they think the leak might be?
Is this a leak that would only repeat when driving highway speeds, with the wheels on the ground?
All insights are welcome!!
No obvious leaks...
