Well this post is basically a hodgepodge of questions but it all stems from the fact that my motor is running too cool and rich.
Lousy MPG, black sooty tailpipe, and stinky exhaust. The temp gauge sits right at the bottom (COLD) and barely moves up from there. It does move slightly after shut down when the motor heats up so I do not think it is the sending unit, also you can place your hand directly on top of the radiator and it's not too hot to the touch to leave your hand there. Lukewarm air from the heater as well. The heater hoses on the firewall to the heater core are warm but not real hot to the touch after ample time to warm up and both heater fans blowing.
I replaced the thermostat with an OEM unit, as well as the gasket and rubber ring on top. I've purged all air from the system.
After searching and reading up a bit, I see some folks talking about the fact that a lean mix will cause a motor to run hot- Well I'm wondering if the opposite is true. I have replaced a blown fuel pulsation dampener on this rig, and it IS running really rich. I'm thinking fuel pressure regulator replacement time? I have a spare in a box that came from SOR and supposedly tests good...
If that doesnt raise temps then I'll try back flushing the heater core and let you all know what happens.
Anyone else have any ideas?
I'm aware of the usual consensus regarding no heat problems, and burping the system, replacing the thermotat, etc. I've done all that short of backflushing the core. I just wondered if running really rich could contribute to the problem.
Sorry for the long post and thanks for letting me think out loud. I'll update as I get it ironed out.
