I've got the cam out of my 2F and the lobes and lifters are showing minor pitting. I'd like to replace the cam, but there is no way that I'm going to replace the cam bearings (motor is still in the rig, and there is no way it's coming out!).
Has anyone had any luck replacing a cam without replacing the cam bearings?
Generally speaking, would a re-ground camshaft have smaller diameter journals, or do they just polish them up? I don't see any mention of over-sized cam bearings in the FSM.
If I do replace the cam, I'd like to get a little more punch between 500 and 3000 rpm. I'm going to talk to Delta Cam in Tacoma, but I am not familiar with camshaft specs. For example, how do I interpret this:
262 duration,217 duration @ .050 with .430 lift
(https://forum.ih8mud.com/showthread.php?t=82083)
Any recommendations for lift and duration that would be beneficial for stock 2F (no intake, exhaust, or compression changes)?
Thanks!
Thanks!
