cam specs. (1 Viewer)
BEND,OR
Here are the specs that Delta Cams sent to me on there KC grind. I'm not to knowlegable on cams .
Do these look good to the gurus ??
262 duration,217 duration @ .050 with .430 lift
I use this cam a lot. Great stick. (I thought that I remember the lift being .441, but maybe not.)
Mark...
This cam does run very close to spring bind. But without spending time to check (which I have not) I am not sure about my memory. It may very well be .430 as stated at the top.
Mark...
JP2ME:
Did you end up using this cam? If so, are you happy with it, and do you have any other engine mods that relate to the cam (intake, exhaust, re-worked heads)? I'm considering a re-ground cam from Delta for my stock 2F.
Thanks for the info
