Cable Run for Rear Light Bar
Mississippi
I'm looking to install two small little LED lights where the whale tale attached. What would be the best way to get the power cables into the cab? A while ago I read that someone used a hole under a factory hole in the roof under the stock roof rack. Any idea how to approach that? Different/better ways?
Thanks,
William
You can use factory openings beneath the roof rack, using grommets for cable protection. Also, check for existing seals in the rear hatch or trunk area to pass small wires through. You can also route the wires alongside existing wiring harnesses.
