Cab swap for 86 pickup
Gueydan, LA
I'm almost certain that this has been covered somewhere, but i looked back in the threads for quite a way and couldn't find anything. And i understand that it is rather straight forward, not very technical, but does anybody know of a thread or have a step by step for removing a pickup cab?? i'd really hate to go into this blind (having not at least read up on doing it first)
It isn't very complicated. Carefully disconnect the cab harness from the engine harness, remove all frame/engine to body connections (brakes, steering, grounds, etc.), take out body mount bolts and remove cab. Her is a link to a 4Runner swap I did with help from an awesome friend and his awesome shop.
https://forum.ih8mud.com/threads/4runner-project.603843/
ooooh watching and waiting. I may have to do this myself to my 83.
Thanks guys!!
and another slightly "noob" like question....how do you guys get your profile picture changed to something besides the default picture, and then get your vehicle info underneath your posts lol
Thanks guys!!
Top right. It will say [my user name] Inbox Alerts
Mouse over your user name.
Click Personal Ddetails
On the left is a menu. Start at the top, and work your way down ... though most of what you want to play with will be on the first page. Also, you might need to increase your post count before allowed.
it looks like i just have to make more posts and stuff. no big deal
and I'll be sure to document this cab swap and make a thread on it for other people interested in a pic by pic thing. Hopefully I'll remember to post it all haha
Doing a cab swap isn't that hard, you just have to be methodical and organized. Take notes and lots of pictures. There's really no "standard" way to do it. The more you strip off the exterior and out of the interior, the lighter it will be. I probably wouldn't just run a strap through the windows and lift it off that way, you risk buckling the roof. My preference is to stick a couple of 2x4s through between the cab and frame, have 3 other friends come help you lift it off. This only works if the tranny is already out, though.
Putting the newer one back on is trickier, getting everything to line up, you can't expect your buddies to hold it up in the air while you run around and line up the body mount holes. When I put mine back on last Fall, it had just been painted, so I really didn't want to scratch it, plus the engine was in already. I made a jig that had 4 pieces of threaded rod that went through the existing holes in the floor, with big washers, nuts, and some 2x lumber under the floor to spread out the load. Then I made a beam that tied it all together, which I hung from a piece of chain in a cherry picker. It was kinda scary having a very shiny freshly painted cab swinging from a single hook inside the cab, but it worked really well, 2 of us guided it back over the frame and slowly down. Once I got it just above the mounts, I was able to walk around and slide my 1" BL pucks and all the bolts back into the mounts. When all the mount bolts were installed, I dropped it the rest of the way down. Worked slick.
I have a butt-load of photos, I'll pick a few out and post them up later. Gotta get back to painting before it starts raining again.
I have a chain fall in my shop that has made life very easy when it comes to pulling beds and such. I've already gotten a replacement cab, have it on stands in my shed, stripped everything but the core support for the dash, prepped to paint and all that good stuff.
My plan to set the body on my frame was to run nylon straps under it and set it down on the straps then get a floor back and just inch it up enough to take the strap out. But first i have to get the other body off and run all the wires in the replacement cab. That should be a blast.....:bang:
