Has the coolant reservoir overflowed? Is there oil in your coolant? What does the bottom of the radiator cap look like? I live in the AZ desert and my 3fe will only get to 220 F when doing long grades in the heat. 3FE tip for you new guys, Put your cruiser in low range when pulling steep long grades and keep the rpm's at 3000 rpm or higher even this will not hurt the mighty 3fe. My cruiser is cooler when moving than when idling. Keep those rpm's up when climbing, down shift early.
