Started in on the sound system this weekend. Most of the time was spent pulling out erroneous wiring and accessories. I estimate about 30 pounds of crap all together. So far only two tweeters are left in the factory dash location. Removed so far, old power inverter, amp, four 6in components, two 6x9 components, two 3-cigerette sockets, ETC (EZ pass) receiver, HID wiring harness, and a few random wires leading to nothing. What was most frustrating was the attention to detail for some parts of the wiring and complete disregard for others. I.e the PO used a combination of: zip ties, twist ties, electrical tape, and scotch tape to secure various things.
This is about half of the crap pulled out.
We did find a harness to what I'm guessing was an aftermarket speed sensor. It starts at the T-case and ended up in the dash. It has power, ground, and ACC lines. Maybe one of you know if it is needed or what it is (black looming)
As far as progress we were able to get the power inverter wired in proper. We didn't secure it yet. I will likely fab a bracket to hold it and the amp together under the passenger seat. Also wired up one door, but I'm not happy with how I cut the frame to fit the speaker so that will be coming out soon enough to do a proper job. I'm likely going to make new door cards as well. So more to come with that. I will also create a sperate posting going into detail the specifics of the stereo install once everything is functioning as it should. We're still trouble shooting some issues.
Big thanks to
@Kenavides for learning me some audio knowledge and putting in work.
Lastly I'll drop a good shot of the little man putting in work on his future truck.
