Good call on the dampener. I forgot to mention that.Installed majority of Budbuilt slider plates. Fuel tank protection coming in a few weeks.
Took longer than expected but by myself. Ramps and floor jack huge help. Rob at BB super responsive to questions.
Couple things to note. Make sure you dont crank down on transfer counter/vibration weights...forget actual name. They are cast aluminum and only need about 6 to 9 foot lbs of tourque. If you go more they will break and are expensive to replace. Thanks Rob for heads up. I have included a pic of them.
Second install bolts loose before you tighten up everything and when you install the BB crossbar make the required cut on the heat shield, and install before installing armor. Obviously i progressed and found out the hard way that's a no no.
These things are no joke so floor jack is a must to help maneuver into place and help with supporting weight while you install hardware. One man can do it but 2 is better plus need a beer gofer.
Also did they change? I put that heat shield back on after I had all the skids installed without a problem.
Do the counterweights need to be removed to position criss bar into place?
Yea, I'm referring to that as well. I took it off, but didn't put it back until after all my skids were installed since I had to find a friend with an angle grinder to cut the section. I took your post about it, as if you had trouble putting it back after installing the skids. I was curious if there is something that blocks that area now to make it a bit tougher if you put it on after the transfer skid plate..Not sure if they did but I'm in a 2018 LC and in order to attach the BB cross bar i had to cut that chunk from the heat shield. Just to clarify, its the heat shield on drivers side frame rail i am referring to.
Should've just gone with a full BB system so you could've had that protection.better picture of the transfer case skid and bracing on this thread than on the BB website. This skid is one of the key reasons IMO to go with the budbuilt system; most manufacturers are ignoring the transfer case or have a solution which actually might be worse than factory.
It's a shame BB doesn't market the transfer skid as a separate piece like the fuel skid.
Maybe!Should've just gone with a full BB system so you could've had that protection.![]()
I didn’t support anything. Did one bolt at a time and nothing shifted. Surprisingly easy. I installed the set of skids by myself in my driveway. I drove each front wheel onto a bag of mulch to lift it a little off the ground. It was just enough clearance to place the skids on my chest and lift them into position to get the bolts secured. My floor jack and jack stands were in my warehouse and I didn’t feel like going to get them. Definitely one of my more creative install techniques.Quick question for those that put these skids on...Do you need to support the tranny/transfer case with a floor jack when you remove those two long bolts and replace with the BB provided bolts to put up the cross member? Chomping at the bit for instructions but this thread has been incredibly useful. Thank you to OP and appreciate responses.
To play it safe do what Bullgump suggested. I didn't, but you could have a floor jack under the cross to be extra safe. Doesn't hurt, the amount it moves is so small without a jackQuick question for those that put these skids on...Do you need to support the tranny/transfer case with a floor jack when you remove those two long bolts and replace with the BB provided bolts to put up the cross member? Chomping at the bit for instructions but this thread has been incredibly useful. Thank you to OP and appreciate responses.
Replace one at a time.Quick question for those that put these skids on...Do you need to support the tranny/transfer case with a floor jack when you remove those two long bolts and replace with the BB provided bolts to put up the cross member? Chomping at the bit for instructions but this thread has been incredibly useful. Thank you to OP and appreciate responses.
