Brake Squeaking on reverse (10 Viewers)
Austin
Brakes would sequel while reversing. Took it in for service for the 10k oil change and brake pads and shims being replaced, apparently it's a known issue. If it's a duplicate thread will delete it.
let us know how it goes
i had the squeals, did a quick on road re bedding no more squeals. Hopefully the new pads arent brake dust generators
That's how you know you have a genuine 250...treat it as a badge of honor
See TSB attached on this
Thanks for the part numbers. It will be a while until I go through the original set so I’ve got time to see how else the formulation change affects the pad’s performance
Yup, mine squeak too.
