I have just replaced all front brake wheel cylinders, pads, springs, etc... And when I was bleeding the brakes I noticed an "air" leak or something coming from the master cylinder/booster area. It sounds like a quick "pissst" and it corresponds with the pedal clunking and then dropping. Did the diaphragm in the booster just go out? The brakes work great when pumped. I have bleed them three times. There seems to be no air in the lines. Every time I pump the breaks it is spongy on the first pump. It only takes a few seconds to get spongy again.
I tried holding the brake while starting the vehicle and the pedal dropped a little, but not much.
As you may gather, I am a rookie and any advice will help. Thanks
