Let’s go about this in a more scientific way, here is the formula for friction:
This equation tells you that when you have the normal force,
FN, all you have to do is multiply it by a constant to get the friction force,
FF. This constant,
is called the
coefficient of friction, and it’s something you measure for contact between two particular surfaces. (
Note: Coefficients are simply numbers; they don’t have units.)
You may notice the formulas doesn’t contain surface area however it is for a set surface area, example would be 1 square inch. The force due to friction is generally independent of the contact area between the two surfaces. This means that even if you have two heavy objects of the same mass, where one is half as long and twice as high as the other one, they still experience the same frictional force when you drag them over the ground. This makes sense, because if the area of contact doubles, you may think that you should get twice as much friction. But when you double the length of an object, you halve the force on each square centimeter, because less weight is above it to push down. Note that this relationship breaks down when the surface area gets too small, since then the coefficient of friction increases because the object may begin to dig into the surface.
So in conclusion within the limit of coefficient( brake pad material design) increasing the surface area(larger brake pad) without increasing force(brake caliper force applied to the pads) the overall friction won’t change. If surface area is increased too much then you will lose friction because not enough force is there to achieve optimum coefficient (highest friction before material breaks down/wear out too fast) which is only achieved at certain temperature which is achieved by having enough friction. This is why carbon ceramic racing brakes feel like skates unless heated up.
Here is a side by side comparison of the 2pads even thought it doesn’t make any difference unless material is different:
80 vs. 100 series brake pads: Picture
