So you can adjust the brake pedal switch. Just FYI
When you install a new booster make sure you adjust the switch
fixed. ID10T error![]()
Brake pedal is not returning far enough to (de)actuate the brake light switch?
Weatherm, I had the same problem on my 72 recently and it was caused by the small rubber bumper falling off of the brake pedal. It is the rubber stop that actuates the brake light switch. With it gone the 1/4" space was enough to not turn the brake light swith off. Small rubber button available from Toyota. Hope this helps! Ben
