Brake job - so easy a cave man can do it! (1 Viewer)
Man, I started taking loose bolts, cussing ( I broke the seal on the system) I realized all you have to do is pull those pins! Wow, Toyota makes some eqisitely engineered products. I want a locker so I'll probably postpone a axle rebuild.
I think a lot of us have found out the hard way how easy it is to change pads.
No abs, I did read you thread, however. I've seen times when folks were pumping to build pressure and shoved the rod in the MC to far in busting the rubber, thus unsealing the system letting air in. If your getting pure fluid out of the bleeders, then it is entering somewhere else. In a perfect situation, I'd take each individual piece and pressure test it. But that would be a PITA!
