As long as your being fairly gently, it should be fine. That's squeezing the soft line, not the hard line.
The two main bolts that are 123nm or 90 ft-lbf)
trying to locate the other two bolts
at best. Thanks to Mo and others on this thread that made it possible for me to even attempt this. Here are my notes:The only problems with splitting the calipers are to make sure that you do not lose/damage the two rubber gaskets inside and I have no idea what to torque the bolts down to when re-installing (FSM does not go into splitting the caliper). I hope that the rubber gasket is not too big of a deal since my left caliper only had one to begin with.
mechanic did the rears in about an hour this morning.My rig was pulling hard to the left under braking. I figured that the front left caliper was not working correctly . When I took off the front tires, I noticed that my pads on the left were almost new and the pads on the right were almost down to the metal!! I assume this to mean that the left wasn't doing anything to help stop the truck and the right was doing extra work.
I removed the caliper from the truck and decided to split the caliper to give me more room to get the pistons out. I was shocked to only see one small rubber gasket inside and thought there should be two (and there should be as the other caliper had two when I split it). Hopefully one will suffice in the left one since the kit does not include those parts.
