Brake booster check valve for a 71?
Sudbury Ontario Canada
Called the local dealer and was told it wasn't available... He can still get the rubber grommet but not the valve. Anyone know if any other booster check valves would work? Ill post a pic of the booster later but the hole w the old grommet is just big enough to stick my index finger in just past the nail... if that helps at all...
A part number would be super cool.
Thanks in advance.
D
Found this one in a pick a part, off of a Toyota Celica, I like that it is all metal!!!
Several years ago, I replaced my booster with one from an early 90s mini truck. I got the external check valve as well. You can see it to the left of the booster in the picture below.
Your local salvage yard should have something you can use.
:cheers:
That's the thing, my 85 fj60 is running a 91 runner booster and that came with a little nub and runs a remote check valve. This one has a large hole and grommet that accepts an intergrated valve like the one pictured above. Just lookin to see which valves are interchangeable with which boosters....
D
Wish I had a part no. but I picked up a check valve for, I believe, a mid 80's Ford truck. I also had to buy a grommet to fit. I know this isn't much info for you but I made it work. I got grommet and valve for around 10 bucks. Take your old check valve and grommet to your local parts store and give it a shot.
Wish I had the old one. Toyota has to still make one that fits.....
D
Bump?
D
I think the pick n' pull is your best bet. You will end up finding a bunch of other stuff you want.
You could call cruiserparts.net in NH. They have one surely. Probably will charge you 15 bucks or so.
HTH
Yeah, pick n pulls are a thing of the past up here. All the junk yards are too scared some pos is gonna sue if they stub their toe. Thanks for the link.
D
