HDJdreams
The way she described it, seemed like something more severe, especially since she noticed it. I told her not to drive it any more.
When I got home I found this!
Well unless someone ate a curb at 111.3 MPH or a 16 foot pothole and doesn't fess up, this will remain a mystery ! get these pictures in, maybe they will warranty itI owned the rig for 2 1/2 years and 40k miles. The previous owner installed not long before I bought it.
Since I have owned it, it has beendaily driver and (sadly) seen ZERO off-road abuse.
Just a lot of carnage thereMaybe yourhas an alter-ego and heads to the hills for some heavy duty high speed ORV use when you're not there. But seriously, what else is broke
Yes, but maybe something else broke first or came apart, causing the shock to break.Looks like it ate the CV boot
Maybe yourhas an alter-ego and heads to the hills for some heavy duty high speed ORV use when you're not there. But seriously, what else is broken?
And the plot has thickened LOL, like mentioned above, maybe something else let loose and caused this to happen ? maybe the CV snapped ?Thenot so much, but my teenager bent the steering and front axle of my 96 playing around on the mountain behind the house.
We haven’t let him anywhere near the 200!
Call me wary, but an alignment check followed by a broken shock might need some investigation. Are you sure the alignment shop didn't make any adjustments and leave something loose?I am stunned, OME is supposedly designed for overloaded rigs seeing thousands of miles of dirt roads and the BP-51s were supposed to be beefier than their normal line.
We haven’t had and collisions, jumped it or anything like that. I have had the alignment checked last week and it was in spec, no adjustment was needed.
I am baffled.
I’ll call OME on Monday. I am extra frustrated it chewed up the CV, changing that out will be far more work than the strut.
(Does anyone have a PDF of FSM for changing cv axles?)
Thankful there was no disasters while driving.
Shaft snapped near base at bottom. It is completely surrounded by the coil. Axle is intact, the boot got chewed. The axle certainly wasn’t flopping around.
I thought it was odd it happened a few days after alignment and tire rotation, but I can’t think of how that could cause the failure.
@duggy - thanks for suggestion. I hadn’t seen any leaks, but PO had used fluid film and I recently used woolwax, so that could have masked a leak.
I wondered if the lower mounting bushing where the bolt goes into the lower arm froze up, torquing the shaft until gave up in fatigue???
