I recently went back to stock wheels from aggressive aftermarket wheels, i'm missing the "poke out" look so i ordered a set of Bora spacers too. Went with 1.25" so i should get that wider stance back.
275/70/18 Duratracs
Recommend them?
PO had 275/65/18 KO2’s newly installed when I picked up my LX. Haven’t used them in inclement weather yet but they ride good on the interstate.
I've seen some people mention adding anti-seize to the mating surfaces. Is that necessary or is it enough to just clean the surfaces well before install?
I just removed my wheels to check the torque after the 50 mile recommended distance. The wheels were a little hard to get off, I had to yank them on one side. I cleaned the hubs when installing the spacers but didn't think about the inside area of the wheel.
275/70/18 Duratracs
no loctite, just torqued to fsm. maybe 10k on them with hard wheeling and changing AT sets with MTs sets on the regular and no problems.
Do the Bora Spacers have the hub ring notches like the Spidertrax ones? With the 1.25" spacers, do you still have to grind down the studs?
x2Yes, the spacers designed for the front of the 100 series have notches and no, you won’t need to grind your studs with a 1.25” spacer. I went with a 1” spacer and still didn’t have to modify the studs.
