crushers said:what i would do is sart low say 10 psi, give a try, turn up the fuel, try again.
You're never going to learn much about your engine doing things this way. I say the exact opposite. Start high... maximize the boost. Then, each time you re-install the engine, turn it back 2 or 3 psi. When frequency of engine rebuilds becomes tolerable, leave it set there.
In all seriousness, the design of the 12HT, 1HD-T is very similar to the Cummins, and they're running 15-20 PSI stock, and regularily upgrade to 30-60 lbs for big power. Our engines already have piston cooling, excellent quality rings, pinstons, rods, crank, and an absolutely gi-normous main bearing cap that makes those ever-so-covetted-stongest-you-can-get 4 bolt main caps look like marimba chimes. Even the head gaskets are a multi layer steer (MLS as it's called in the racer crowd, sometimes called a Cometic gasket) which is what the hot rodders are abandoning their o-ringed copper gaskets for. I wouldn't hesitate for a second (there's got to be a good turbo-lag pun in there somewhere) to run 15 to 20 lbs in a 12H-T or 1HD-T. THe ONLY thing I would ever think that needs improvement on a 12H-T/1HD-T to run higher boost might be replacing the head bolts with Studs. But that's it, and for 20lbs, it's not a concern. I would, however, run an intercooler if you're pushing more than 15 lbs for more than 30 seconds at a time (i.e. towing)
An indirect injected engine, however, is a different story. I would jack the boost up on one of those as high as I can too, but when I pull it's blown ass out of the truck, it would be replaced with a direct injection engine.
I really should get my ass in gear and build that super-turbo charged 1HZ and prove once and for all just how much boost you really squeeze through an indirect injected engine. If only I had an FJ80 carcas to install it in....
Peter Straub
