bolts holding the diff carrier / third member: easily replaceable? (1 Viewer)
e9999
Gotta get out there...
Moderator
US
are the dozen or so bolts sticking out of the axle housing that hold the diff carrier / third members in place readily removable and replaceable?
thanks
straight forward then? nothing like factory thread locker or ungodly torque or anything like that?
I replaced mine when I regeared/added lockers. Go get yourself a set of these...
OTC 6987 4-Pc Metric Stud Remover Set - ToolKing.com
and its a piece of cake.
It also makes it much easier to clean off the mating surfaces before you put it back together.
how do these things work?
can't you just use a couple of nuts?
It'd be nice if you can get a Torx or hex stud or something equivalent
Some stud removers I've seen have internal fingers that grab the stud (Mac tools) some others kinda dig or cut into the part (Craftsman) thereby holding it while you back it out with your wrench.
that sounds pretty destructive. Could also use one of those bolt-outs for that, if small enough.
When I retro'd my rear factory locker I had to replace a handful of these. It was no problem. I even had to do two with the diff partially installed. I used the two nut method. I was a PITA but it did the trick.
However, I bought the OTC kit for doing the front. I have not used it yet.
thanks
Straight forward if you don't have rust issues. Use 2 nuts, a spanner to break, then a gear wrench to spin them out. Front is 12mm, Rear is 14mm.
-B-
Why are you replacing them? The lower ones sometimes get booggered up on rock, but they hold up pretty well.
The easiest way to get them out is destructive. Unscrew the nut to the end of the stud, weld the nut to the stud and back it out with an impact. It's very quick. Replacing the studs is much easier with the diff out. I don't know that I'd try it with the diff in place.
you can upgrade the fronts to rear size by drilling and tapping while out, and getting rear studs and nuts, and drilling the carrier.
The studs in 10mm are different part No, but same stud as 10mm axle studs on 105 cruisers.
That is a very good idea. Is it possible to drill and tap in place, or do you have to pull the axle out from under the truck?
you can also screw 2 nuts on the bottom ones prone to damage, to protect the thread.
that's a very good idea, too. Wish I had read that earlier... :whoops:
It looks like socket and you slip it over the stud and turn it with a ratchet, it does have internal finger that grasps in either direction.
Yes as several people pointed out you can use two bolts but these tools remove and install studs with no damage and without any fuss.
I have used mine to pull broken studs with damaged threads that made the two-bolt system impossible
I have to disagree ... the easiest way is with the right tool :D and no destruction is involved.
so can you get replacement studs with a hex or Torx head or something like that to make it easier to put in and remove?
You really shouldn't need to be taking them in and out often. Unless they're damaged there's no reason to even dink with them.
