Blue Sea ML-ACR 500 AMP Dual Battery with remote wiring and modification to isolate when car off (1 Viewer)
Hello everyone. I relay on this website a lot so im want to give back a bit.
To get started This is what I have and a Modification that i has made everything work way better.
The modification is that when the car is OFF, the batteries are ALWAYS disconnected, so you always have one battery safe from the other.
dual battery set up (OPTIMA YELLOW TOPS)
Blue Sea ML-ACR 500 AMP with remote Automatic Charging Relay
Amazon.com : Blue Sea Systems ML-ACR 12V DC 500A Automatic Charging Relay with Manual Control : Boating Battery Switches : Sports & Outdoors
So basically, here is the wiring diagram from Blue Sea
as you can see its pretty basic, you only have to connect 3 wires from the unit.
The RED wire, goes to the remote 2 spot.
The YELLOW wire goes to the remote 7 spot
The Brown goes to the IGNITION of the car.
why all the extra wires? (the Brown, Green and Orange all do the same, so if you have a machine or boat with 2 engines you can isolate when any engine turns on)
Now, from the car you need a Positive and a Negative.
POSITIVE goes to 8 and 3 on remote
NEGATIVE goes to 1 on the remote.
Up to this point is basic
TIPS.
Take the positive ONLY from 1 of the batteries, most likely the STARTING or MAIN battery. The battery you will most likely always have on in the car, so you always have a positive line active.
Put fuese on all positive line cables, this includes the BROWN wire that goes to the ignition switch.
Where is the ignition? if you have never taken an IG line then just go to the main fuse box inside of the car, look for the IG logo, and take it from the cable that is connected AFTER the fuse
If you have accessories already connected, you can take the IG (Ignition) line from any cable that is already IG, but put a fuse (2-3.5 amp) smaller the better.
It does not matter which battery goes to A or B port of the unit, its just a cut out switch, so it does not care if A is start or main, or aux or whatever or if B is. It only senses voltage from both ports and lets current thru in both directions.
Ok, now to understand how the system works and why It need a Modification in my opinion.
The Blue Sea ML-ACR works by combining the batteries if several things happen. (when remote turn to auto)
1. If there is a voltage source that is over 13.5 volt going to either one of the batteries (A or B terminal of the unit) for more than 2 minutes
1.If both batteries are at least 12.1 volts (or 12.3 i cant remember). Basically, if both are ok healthy, so if one battery is at 7Volt, and you turn the car on, and it connected the batteries together you will ruin the good battery with the bad one. This is the reason why this is there.
Ok. Now for how the ML-ACR works when the batteries are ALREADY connected together, so, how does it know to disconnect them??
1. if there is a voltage ramp from one of the ISOLATION WIRES (Orange, Brown or Green) this is why when you are going to turn on the car and the remote is on AUTO, it will isolate the batteries and use only the STARTER battery to start the car, from there it goes into the wait 2 min, is the voltage High enough, etc.
Understand its a RAMP, so it does not need to stay ON for the batteries to disconnect, a simple 12Volt then 0 Volt will do to isolate the batteries. This ramp is a positive one, so going from 0 to 12 volt, not from 12 to 0.
2. If either of the batteries drops below 12.65 volts, the ML-ARC will disconnect the batteries. this is to make sure if you have the batteries AUTOMATICALLY connected together and you are running your fridge, or lights or stereo, when the voltage drops to 12.65 it will disconnect the batteries, and then your stuff will be only running from wherever you have it connected, most likely your AUX battery.
THIS is where the mod comes in. lets explain why.
If you have normal acid flooded batteries, 12.65 is preatty good. If you have Red Tops 12.65 is good. IF YOU HAVE YELLOW TOPS OPTIMAS or any other DUAL PURPOSE SEALED AGM batteries then thats a bad number.
Yellow Tops are good on 13-13.2 volts, fully charged.
So if you have a very good new battery, that charges and holds 13.2 volts, and another crappy battery, that charges and holds only 12.8 volts. When you go for a drive, the batteries automatically connect together, fully charge and then you stop, park the car over night and go to sleep.
over the night the healthy battery wants to stay at 13.2 volts, but the s*** one will want to go to 12.8, so they start to steal charge from each other, the good battery gives voltage to the bad battery until they both are on 12.8.
this does not sound so bad but think of it this way, 12-13 volts is your only usable voltage range of a battery, so this 1 volt is 100%
if you drop from 13.2 to 12.8 you just lost 40% of you energy, usable energy, just because one battery stole it from the other.
And since both batteries are still over 12.65 volts, the Blue Sea ARC will not disconnect them, it will keep them together, until this keeps on happening the bad one eventually only holds 12.6 volts (which is a good holding voltage for a normal flooded battery) and then it will disconnect.
The bad news is since this is every night you just ruined your yellow top because now it also only holds 12.6 volts, because you are recharging it every day forever!!!!
another example.
You have a dual battery system but now you have a RED TOP and a YELLOW TOP.
they will get combined under normal driving, then you turn off the car go to sleep, since the holding voltage is different, same thing happens, the RED TOP will steal from the YELLOW TOP until they both are equally at the lower voltage. 12.7 if your red top is brand new, or 12.65 until isolation from the sistem
since there is no factory way to make sure your batteries are disconnected AUTOMATICALLY when you turn your car off, you have to manually switch it to OFF, and make sure you put it in AUTO or ON next time you start the car.
so looking at the wiring diagram and doing some testing I noticed that the unit Isolates the battery when the REMOTE cable feels a ground or is Grounded permanently.
on this line of thought what i did was put a relay that is Normally Closed connected to ground and the REMOTE wire. and activate the relay with the IGNITNION voltage so that when ever you turn the key to IG the relay will be open and the unit will function normally.
here is the modified wire diagram
To explain.
the relay is in the natural state of NORMALLY CLOSED, so if you dont do anything to it wires 30 and 87a (black and blue) will be connected.
if the relay gets activated by a 12 volt source on pin 85 (pink wire) then it will OPEN THE RELAY and you will nave no continuity between pins 30 and 87a or Black and Blue.
since the IGNITION wire or PINK wire is at 0 volt when the car is off or the key is not in the IG position, there will be a GROUND on the REMOTE wire, thus Isolating your batteries.
But!!! if you turn the car on! or put the key on the IG position, the relay will activate and disable the force Isolation, thus putting the Blue Sea back to original function and waiting for the necessary events to connect the battery.
This mod has worked wonders on my car. Now every morning both of my batteries are on 13 volts (12.96 and 13.1 to be exact) before, every morning both were on 12.65volt since they were battling each other all night.
Now every time i park at for overnight camping my start battery is totally isolated and i dont have to worry that if a do a stupid short of something catastrophic happens, its all disconnected.
Also, if i ever need to put a normal flooded battery in the car because one battery brakes or waterer i dont have to worry about only having limited voltage.
in any case, this is my long story and hope to help someone.
on a note, and help needed on this. if you for some stupid reason move the remote to the ON position while the car is OFF and the key is not in the IG position, you just sent voltage from the battery (pin 8 on the remote) to ground (thru pin 87a and 30) so you just short the ignition fuse. to fix this i was thinking of puting a small light on this wire from 87a to REMOTE, basically put a light in the middle of the blue wire. So if you ever do this a light will turn on and thats it, then you know you have to put the key in the IG position, what do you guys think?
thanks again for reading.
Thanks for the info. I need to read up a bit more about this unit because I'm looking into making a complete plug n play kit but I have very little experience with it. I have one install out there being tested.
View attachment 1494097 View attachment 1494098
Nice!
This is literally what I have installed in my car. Braker, box location and all!! Jajaja
Mine is between the battery and the panel. Because where you have it is where my Snorkle goes in. So no space. I have another brand. Not Safari thow.
I am the first to modify and and try to make something better or more suited to our own needs but, feel you have shot yourself in the foot with one.
We isolate batteries to protect one from the other and the BS VSR does this with no fuss, mine having been in the 80 for around 5 or 6 years without issue.
If you wanted immediate isolation of the batteries why not just buy a Cole Hersee relay and fit between the batteries and wire the actuation direct to the alternator? You switch off and batteries are isolated, start the engine and they are combined, job done for around 3% of the price of the BS VSR.
Your calculations for battery power percentage loss based on voltage are wrong.
And given the only time we need to combine may be a winching operation, or we need to jump start our own motor, and press the remote to couple the batteries only to blow a fuse because we forgot ignition first in our hurry to get going, sorry IMO this not a modification I would recommend.
Regards
Dave
Regards
Dave
Well. I hear you for sure. I want with the blue sea Because of the 500amp limit and the automatic connect and all that fuss.
But on the mod if you do put the light on the ground then you can still combine the batteries even with IG off. And if you do blow the fuse of the blue wire the car will still run and the batteries will also connect. So no problem
Also if you are winching with the car off that's an entire bad idea all together.
I
Thanks for the input thow. The mod has worked for me.
Also. Thanks for all the stuff on my alternator. It working better now as well
Also. What is the BS VSR? I'm sorry. I haven't heard of this. I'm in Colombia South America so we don't get any of the good stuff.
Sorry, BS VSR is 'Blue Seas Voltage Sensitive Relay'.
As I said earlier, I am all up for mods but the BS VSR is designed for marine use, in other words well thought out designs and constructed equipment, which is why I use marine gear including batteries wherever possible.
I would not advocate winching with the engine off, my point being that if you need to winch, or you have a need to combine batteries it is rarely planned, you jump in and press the button and oh sh*t I should have switched the ignition on first, now you have blown the ignition fuse adding to your already needy situation.
Don't get me wrong I am not trying to rock your boat, but I am saying you have purchased an expensive piece of kit and then bypassed it.
Regards
Dave
Regards
Dave
Hey men! Yeah, no problem, no offense taken.
And that is exactly what happend, I didnt know this isolator would leave the batteries combined after i turn off the car. I was bummed about it to say the least when I called Blue Sea and they told me that is the normal situation. Since I live in South America and shipped it from the USA its more expensive to return than to buy a new one.
In any case, this is why I thought hard about the mod and made it happend, after the mistake of getting it.
On a question, which VSR do you have exactly? I just went onto the BS website and it just thru me to the ACRs. Thanks
No problem mate, you can see why I qustioned the thinking behind the mod knowing you had spent so much money, I am pleased you checked with Blue Seas they really know their stuff.
Re the model in mine, I cannot recall if this number is correct 7622 perhaps?
Mine is 500 amp and dual sense, so you can charge to either battery and both receive at the same time.
I charge auxiliary battery from the alternator and the VSR makes sure both are charged, my solar panels charge the starter battery, and again the VSR does its job. For me it was the 'fit and forget' nature of this particular system I like, and not having to reference it for years at a time shows how good the system is.
Will you remove the modification or at least install a warning on the switch so you do not blow the ignition fuse?
The amount of loss of battery power is extremely small when the VSR eventually detects a battery voltage coming down. When I park my car and set the alarm the small parasitic draw is carried by both batteries, depending on temperature the VSR will keep the batteries combined for perhaps two or three days, and rarely four, and then the VSR isolates the batteries from each other, the 'aux' battery now takes the load, the starter battery isolated from any drain.
You have to remember BOTH batteries are monitored, so it does not matter which combination of batteries you use (although mixing is not IMO good), the VSR checks and if EITHER of the batteries voltage matched the VSR factory setting it will disengage, thus ensuring you have at least one healthy battery.
Glad this has all been clarified, and kudos to you in an attempt to make a good system better.
Regards
Dave
Regards
Dave
Nice! Wish i saw that option before. But the ACR works very well. I just particular I want for them to be isolated when off.
And yes. I installed an inline 2 amp fuse in the blue wire. So it will blow if I try to connect and protect the IG fuse. I did this from the start but don't put it on the drawing.
I also just got a solar panel 100 watt.
I got a dual battery solar charger so this is another reason why I want them to be isolated if car is off. So the controller can charge the batteries independently. I'm setting it up so the solar panel gets activated only if the car is off automatically.
Have any pictures of your set up? Is the dial battery solar charger an overkil?
Thanks!
I think overkill is not an issue if you go to remote areas in particular when alone, I need a fridge as well so need to keep that running. A relay is used to isolate the solar panels that are connected when camping, if you start the engine for example.
If you click on the link in my signature it will show different mods I have made.
Regards
Dave
Regards
Dave
Cool. Can you send me the link? For some reason I can't click on the signature.
Thanks.
I really don't know how much, but I can tell you that working with Joey on this. Unless, you plan on selling the product,
1 prototype may cost you more than 10 to produce. Usually, it's just not worth it. Also, after using it for a few years, there is an inherent weakness in the design and I wouldn't make any more with that design. The bracket ended up breaking at it's weakest point. I'm now using it as 2 separate parts and it's easier to get to the air filter, and doesn't stress the metal when it was 1 piece.
I am not sure if this belongs here but I do have a question specific to the Blue Sea ML-ACR. I just completed a dual battery install in my Tundra but am having trouble with the relay.
When I have the switch on Auto it will connect the batteries (light is on and mag lock is engaged) even while the vehicle is off. I even waited for a good 30 minutes but the light is still on denoting that the batteries are connected while my truck sits completely off int he driveway.
I just went out and manually shut off the relay so I don't have battery issues in the morning... just in case.
Any help would be swell.
