You don't need ought (0) wire. #4 would be more than fine. Welding cable is ideal for price and availability. Consider a breaker at the battery side feed to give circuit protection and convenient "off" switch for maintenance.
2000UZJ said:Slooooooow progress.
Mounting location determined and tray fabbed up. I went through three pieces of steel. I have no bender, which makes it very hard to make nice bends. Pics of first attempt. I have added aluminum bracing to the bottom to minimize vibration, not that it matters, but just for good measure
RobRed said:Step 1. Steam clean that engine bay!
Skidoo said:1407driver - I leave switch on with power to starter and winch, turn off for more security when leaving truck in wilds.
2000UZJ - that sheet metal mount is way too thin for offroad, it will constantly flex and eventually break off.
Try brushing with baking soda/hot water.I cannot for the life of me get the original battery terminals off, so I can't connect the power cable how I want it. I have been soaking it in PB for a while now and still won't budge. Any suggestions?
While you are at it, I would highly recommend upgrading your terminals too!
I try to do it annually (due now). It comes back factory new looking. Makes digging into projects so much nicer.
