- Thread starter
- #61
Small victories....
The drivers side is pretty much like the other, but there are a few small differences. For some reason Toyota thought extended a rib on the floor right into where I needed to put the A-pillar floor pad. On the passenger side there is no rib in this location. I wanted the parts to match, and I didn't want to have to cut out a section of the floor. I started with the saved template from the other side, I just reversed all the bends and flipped it over. Coming up with a way to press that rib into the bracket was interesting....
Scrap metal press brake tool for the win. It wasn't perfect, but it worked rather well for a one off tool with a minimal time investment. Sometimes it is not the tools you have, but the ones you make along the way....
I also sectioned and relocated the dash corner on the drivers side. This side was a bit easier because I didn't have to work around or inside the glove box. It was much easier to get access with the hammer and dolly when doing the seam work.
Now onto the A-pillar tube and then hopefully the fancy rolled windshield spreader bar this weekend. Once all that it fitted I also have to make all the gussets, weld them in, weld the plates to the floor/dash, etc. Lots to do, but it will feel SO good to have a complete cage! Once that is done I can move onto some different stuff like making the rear sheetmetal. I also need to think about making the tunnel soon. I also have an idea for a new press brake tool that I am thinking about constructing....
