After destroying 2 x 3B engines, Original by hitting a Kangaroo and trying to get to next town and relying on temp gauge, Total overheat and cracked everything.
Bought a so called reco engine that had only done 30k and it lasted 2k, Valve seats collapsed and took out No. 1 Piston and liner.
Now my problem, It is all back together and trying to start it, Has been fitted with new liners, pistons and head. All was done in the Toyota Coaster so never removed engine. The fuel pump is inline. Also the fuel pump was not removed from engine.
I cannot get fuel up to injectors, Even cranked it over with no glow plugs and nothing is coming up to cracked nuts on injectors. It was running till I pulled it down.
Would fuel come out the top of injector pump line outlets on pump if using the hand primer as I tried that before and zero fuel was showing up. I haven't removed the fuel filter or tried bleeding from their.
It has been off the road for maybe 3 months now. Any help appreciated.
