BJ70 axles
Jan-78FJ40
I need to do the front axles on my 70 soon (1985 BJ70, Canadian spec), since I doubt they have ever been done, and are starting to leak a bit after long drives.
Does anyone know if the seals/gaskets are the same as on a 60? so can I just buy a complete kit for a 60 from SOR or CCOT, and it will fit? same question for the rear axle (semi floater).
Also, the rear brakes are blocking easily when wet, so will the cylinders/shoes/drums/springs from a 60 fit?
would I better get everything from Toyota throuh Dan, for example?
thanks for the help,
Jan
lowenbrau
Rockyview County AB
Its all identical to a 60 of the same era. Toyota improved the parking brake bell crank by putting a brass bushing in it to reduce the dissimilar metals problem. This is the only part I'd buy from the dealer and then only if yours are siezed. Otherwise its all jobber.
cruiseroutfit
Supporting Vendor
Moderator
Utah
Yup, same as all the 9/75'-90' Landcruiser and Mini-Truck/4Runner solid axles. Shims will be the bigger ones (included in the FA7590 kit, $87).
Hope that helps
