This site may earn a commission from merchant affiliate links, including eBay, Amazon, Skimlinks, and others.
rock scientist..
Staff member
s-Moderator
Moderator
So the caliper mount is in between the spindle and the knuckle. How did you account for the added width?
"Hallucinations are bad enough. But after awhile you learn to cope with things like seeing your dead grandmother crawling up your leg with a knife in her teeth. Most acid fanciers can handle this sort of thing. But nobody can handle that other trip-the possibility that any freak with $1.98 can walk into the Circus-Circus and suddenly appear in the sky over downtown Las Vegas twelve times the size of God, howling anything that comes into his head. No, this is not a good town for psychedelic drugs."
rock scientist..
Staff member
s-Moderator
Moderator
BTW, that is an interesting idea, but that's gonna drag the crap out of the tire in turns..
Spindle goes on then the caliper bracket goes on using longer bolts
The added width comes from the ifs hubs and the slip on Tacoma rotors are 1/2 thick at the mount surface.
This allows me to remove the entire assembly as a unit. I only have to pull the caliper then remove the hub face and snap ring and the spindle bolts too change a birf
The kit is from frontrangeoffroad
You can put Tacoma calipers and rotors or tundra if you want
I'm hoping with the 51/2 inch backspacing on my rims it won't drag that bad
rock scientist..
Staff member
s-Moderator
Moderator
Ahhh, I was thinking that the caliper mount was inside the spindle, not outside.
Cool.
Loving this build thus far!
The biggest benefit for me with this setup is its now a unit bearing basically keep the mud and snow out of the bearings
I can snow wheel almost 12 months of the year in northern bc
rock scientist..
Staff member
s-Moderator
Moderator
How is the bearing style different than before? Or do you mean if you have to change a birf you do not have to pull the disk brake off?
ill have to post pics to better explain it
rock scientist..
Staff member
s-Moderator
Moderator
From the sounds of it, he's using this kit. The "unit bearing" is that you can remove the selectable hub face, remove the outer c-clip on the birfield stub, then unbolt the spindle from the knuckle and slide everything off:
Tacoma Brake Mounting Kit
rock scientist..
Staff member
s-Moderator
Moderator
Yeah, I get that you can pull the hub off as one piece, but the seals are still the same. The benefit is only when replacing a birf out in the field right?
It won't seal any better than the stock setup when just driving around. Unless I'm missing something (not a first).
Once you slide the rotor off remove the dial face and snap ring then remove spindle bolts and it comes off as a unit
Correct. Secondary benefit is that you have increased your WMS width as a result of using the IFS hubs instead of the stock hubs.
Yes the seals are the same
And it makes field fixes easier and quicker
rock scientist..
Staff member
s-Moderator
Moderator
Unless you pulled the entire knuckle off instead of the bearings before
I did the IFS conversion with spacers back in 2004 IIRC. That and 2" BS rims required hydro assist for almost everything...
Keeper up!
Looking at the clearance between the highsteer arm and the nine wide rim I'm hoping I don't have that issue
rock scientist..
Staff member
s-Moderator
Moderator
Yeah, it's gonna be a bit still turning with that much Scrub radius. Not impossible in any fashion, but definitely harder on things.. Keep an eye on your knuckle studs, they'll likely loosen quite often.
The plus side is that it is dirt easy to do Hydro assist on a FJ60 box.
Yeah I wheeled Lwb samurais for years on toy axles with 2 bs wheels so I know about s*** turning radius lol
Definitely going hydro assist as most of those years was on 36 inch tires and no power steering. Only on my last one did I finally put power steering and I won't go back to strong arming it. Lol
