Builds BJ 45 restoration Greece
And i installed the battery and radiator bases. Under the radiator base i put a rubber piece to replace the mats it had from the factory, and between the battery holder and the bracket, i put two rubber pieces from rubber inner tube. From the factory it had a rubber paint on the battery holder that did this job.
Finally the chambers came.. They were a little taller and they exceeded the heads surface...
I bought an injector nozzle tester. After i cleaned the injectors, i tested them and they were working perfect. I bought some new coilovers but they didn't fit... 😋😋😋. These are for my corolla...
And finally today i made it and the engine worked again... The video doesn't upload...😭😭
Mine is intalled just after the manifold near the firewall.
That’s the right way. Shown’s would work if the bracket to the transmission bolts would been installed (painted silver in my picture):
Thanks for sharing... I didn't knew that there is a bracket for this point. I might try to build one. Seems pretty logical to be there. Mine old exhaust, was exactly as i build the new one...
A flex pipe on these 3b's is essential ! For years the exhaust would crack on mine due to vibration until I welded in a flex joint. Mine is intalled just after the manifold near the firewall. great work !
Thanks mate. Maybe yours is the best way as maTTi says. I'll try to build a bracket...
