A couple of years ago I noticed my power steering would fade and not work sometimes when stopped to negotiate obstacles on the trail. The ps pump would get super noisy too so I figured I needed to flush the system at least if not install a new pump. Over the years I would also notice the steering would intermittently get heavy sometimes just maneuvering in a parking lot without rhyme or reason but never paid much attention, just figured i needed to get around to that flush... but never did.
A few weeks ago the pump started making noise sometimes just cruising around town, under a load. I also noticed the pump was starting to leak so I ordered a new OEM. The day I picked up the new pump the old pump totally failed. (Note: A loaded 80 series on 315s is not fun to drive without power steering.) After the new pump install and flush (the fluid was a little dark but not terrible and no metal) the ps seemed to work fine. I thought for sure the pump would take care of that intermittent binding issue but much to my dismay I have found it has not.
So I have spent some time trying to figure out exactly when the problem occurs, and here is the weird part; It only happens after the system is warm, when the truck is or is almost completely stationary, and when the truck is facing downhill. I turn it around uphill, maybe a 6% or so grade, and the steering is smooth as butter in a full sweep from left to right. I immediately turn it around and stop and it starts to get heavier and heavier the closer it gets to the stops, to the point that it feels like there is no ps. I think it has had this problem the whole time. Weird.
The gear is all I can guess. Any other ideas?
