Finished up doing my front axle reseal and rebuild. At the same time i did the Martack in the axles and swapped sides with the outer birfs. Drive side is fine everything is where it should be. On the passenger side the birfield is sticking out past the edge of the spindle about 3/8 farther than normal. I know the tack weld is in the correct location, i did the tack and installed inner shaft and measured checked to see if it is at the correct location on the seal. That was kosher. I installed the birf to shaft and slid it home. I reassembled everything and noticed that when i tried to put the end cap on the axle was sticking out farther than it should. I am trying to think of where i have the play. Probably where the inner shaft inserts to the birf, but is there any other things to check. When i did the rebuild i did not lock my front locker, but everything came out and went in fine. I also didnt reinstall the shields for the disc brakes but that shouldnt matter since it was not part of the spacing of the spindle to the knuckle. I know i will have to go back in the knuckle, just want to see if anyone else had something like this happen to them.
Thanks!
Thanks!
