I'm rebuilding the front hubs because I had diff oil leaking into the hub and a lot of play in the steering.
I replaced all the steering knuckle bearings and races. I used the old shims. I tightened the four top nuts and four bottom nuts pretty tight, but not to 71 ft/lbs. I had about 8-9 lbs on the right sided and when I moved the knuckle I could feel slight bumps on the bearings. The other side was about 7 lbs and smooth. I added another thin shim to the right side and it is a little smoother, but not smooth. It pulls about 7lbs now. I also feel a groove in the straight ahead position that I don't remember being there before I added the shim. I can move the knuckle back and forth 1/2 to 1 inch and feel increased resistance if I move it further in either direction. If I move it quickly, I don't notice the bump and it's smooth.
My questions: Should the knuckle move smoothly or should I feel some resistance on the bearing? When I added the shim, is it possible I damaged the top or bottom bearing when I beat off the knuckle arm? It was in the straight ahead position when if pounded it off and now I have a little play in this position.
