Bilstein 6112 Dilemma on GX470...not as low cost as I thought (5 Viewers)
Gotcha. I presently am still running my bilstein 5100s with Moog 81108 springs which allegedly are 650 ish lb/in so I am right there too. My current setup isn't bad by any means but upgrades get you looking further and further down the rabbit hole. My only beef is that I still get some brake dive and body roll that I was hoping to have minimized more than I did. I guess I'm spoiled by my Miata and big ole suv's will just have lots of body roll and brake dive no matter what.
I've been leaning more toward Dobinson just due to proximity since they are a few miles away from me.
Either way, I think for the time being I gave up on shock upgrades for now and will enjoy what I have and reassess down the road.
@andymmiami
Late to the game on this thread.
Did you get any lift from the Moog coil length or use the preload setting on your 5100?
thanks
I’m having the same issue and came to Ih8mud to see what I should do. Grateful for the community posting all this information. I also only have 50k on my 6112s with maybe two times out wheeling fairly easy stuff and both shocks are leaking. So I’ll probably go with the 700# as well since I have a roof top tent and a hidden winch I haven’t put on yet. The 600# coil rate with the RTT definitely had a noticeable brake dive. @HomersCanyonero do you have a part number for the 700# springs with the 6112 as a kit? I’ve called toytec and they think it might be a separate sku where I might have to get the 600# that comes in the kit and the 700#. I don’t really want to do that and wanted to see how you handled it
Edit: found the part number. For anyone interested part number is 47-311190 but it seems like it will be 750-800#. The seller is getting me exact numbers from Bilstein
From the seller: Fitment Note : Provides 1.7-3.2" Front LiftFor 150-200 lbs additional front weight, Requires use of 2X Toyota Upper Shock Mount Assy 48609-60100, B8 6112,
E4-FD1-Y005B46 are the 700lb springs, it’s kit 47-311190. Bilstein def doesn’t describe their kits well at all. And you’ll want those top hats they are taller than the stock 470. I just installed 6112s I’m a little bummed they are leaking at 50k I’ll have to keep my fingers crossed
Thanks for bringing up reliability. Now you have me thinking…back in 2006 when I put basic OME shocks and springs on the 80…those puppies have lasted over 100k miles.
I think that was too much to expect from the Bilstein 6112s and I hate the notion of rebuilding every 30k. Arghhh.
The Ironman FCPs likely have a leg up on everything else regarding longevity since you can rebuild them at home without special tools or pressurization. Though I have also seen people of the internet getting very long service intervals out of a few different monotube options like Dobinsons or the Apache AX2. I have like 25k on my Dobinsons MRRs and they are still going strong. I am hoping for a 50k service interval but I am also not easy on them so we will see.
I'm at about 45K on my FCPs and they are still as good as Day 1. They are also a flat-out awesome shock for towing use.
For anyone getting the 47-311190 kit, I’ve talked 4 wheel parts down to $760, while Toytec wants $900 or so out the door. I have found them cheaper online but they are so low I’m afraid
$604 at RockAuto (+5% off if you have the coupon code)
Another thing to note. Bilstein has a lifetime warranty as long as you are the original purchaser. I have the 6112s on the front, 5100 rear and I have jumped the GX 4 or 5 times at 30-40MPH and my unmaintained road is really bad but I go 35+ down it twice a day without any issues yet lol
same setup here and I try to hit the dirt "short cut" back every afternoon lol. it's packed dirt with some dips and washboard. I usually take it at 35mph. No jumps but the suspension gets a good work out. probably why the rear shock nuts loosened up 😁
It seems like most of you are concerned about off-road manners. How do these Bilstein setups handle on the freeway? If I want to hit any trails, I'm an hour plus on the freeway to get there, so I need to keep that in my decision process.
I appreciate the note from @helocat regarding parts/service for suspension.
Lets say I never take the GX anywhere more serious than some forest service roads, what kind of service life should I see from shocks and springs? I'm just guessing, but I think I'm on everything that it rolled out of the factory with.
amayama wants $589 each for the oem rear shocks. Bell Lexus wants $664
So, let's say I want to keep stock tire size and just have the suspension height be at "H" height all the time (I guess that's almost no lift)? and be at least as good on the highway as it was when new, what does a guy do?
on highway they feel a little firm, "sporty". Not jarring. I can't really say how it compares to brand-new suspension but it's definitely tighter than the old OE suspension mine had when I got it.
If I remember correctly Bilsteins have digressive valving so they're firm for the small fast bumps but soften up for the larger bumps.
I've done some reading regarding the valving (digressive,progressive,linear) and have emerged from the fog of confusion a bit. To put a very simple view on it; it sounds like around town digressive might be a bit harsh over typical potholes and other pavement issues but be reasonably firm on the highway and then be decent for bigger humps and ruts off-road?
It does look like I can get a pair of the oem electronic shocks from a few places for what a single unit costs elsewhere, that eases my mind a bit. freshening things up for $600 instead of $1100 is a much less bitter pill (ignoring the front obviously).
I'm in a similar situation to what I was into in my 80 series. I've never driven another GX. I'm not sure how they should feel stock or otherwise. I'd ridden in a family members '06 and I've ridden in a newer gx460 but that's it.
I need to find an applicable stretch of road and see how things are when I mess with the "comfort-sport" dial maybe?
that sounds about right. Bilsteins are known to ride firm. Some people like it (me) and some people don't.
As long as they're from legit sources. I think someone on this forum found fake ones being sold on eBay. They were much less expensive than from a dealer but had somewhat convincing looking packaging.
Yep, taking a familiar path on different settings would be the best way to test if they're still working. Also take a look at your rear bump stops. iirc, they should look like a "8". I think they're likely to get busted in half if the shocks aren't working very well. I remember having to keep mine maxed out on "sport" or else it would feel floaty and they would bottom out quite easily on dips that I didn't think were very big.
good notes. I've been trying to assemble a timing belt/water pump kit and have been wary of a few sellers having prices that are crazy low.
Does anyone have an idea how long the Eibach GX470 kits have been around? It seems like they are pretty new so maybe not a ton of user reports yet?
I also did a bit of looking at other global parts specifically for the 120 platform, and the Koni raids show up and few Aussie brands I hadn't heard of.
I think I'm firmly in the "research" phase unless something on mine breaks or fails.
