biggest tyres on '91 4runner?
Waikato, New Zealand
Hi guys, will 33x12.5x15s fit on an unmodified '91 4runner?
only one way to know,(other than a wise person) Try it out! Most likely will rub.
No they won't. 32x11.5 fit.
To fit 33x12.5 you need to crank the tbars, lift the rear about 2", 1in body lift from roger brown, and do some slight trimming of the plastic near the front fender. It's a pretty standard recipe.
i had 33x10.50s on my old 89 pickup with a 1" tbar crank and no rubbing because the front suspension barely moved.
NO.
I tried it yesterday w/ my new MT/Rs. Rub a dub dub. Cranked the torsion bars and still rubs when turning. T'is ok, just need to install the lift.
I'd recomend doing a liittle lift, my 94 4runner has progressive rate rear coils from napa ($180) and swayaway T bars ($110). The rear coils didn't give me much more lift but the tail doesn't sag and it ride soo much bettter. oh yeah and rancho shocks.
I have run Mickey Thompson 32x12.50's on the 15X7 toyota alloys with no clearance problems, and these tires are almost as tall as most radial 33's.
Right now I lowered the front back down and put 31x12.50 xterrains.
I think some radial 32's on the toyota wheels will work no problems for you.
