Big 3 upgrade GX470 (2 Viewers)
Sacramento
Can someone post photos of how they ground the engine to the frame? i cant locate the stock grounding cable. I did the alternator to + battery and frame to - battery. thanks in advance.
Not familiar with this mod.
Have any more details or a link?
the reason for this is because during an idle at a stop light, my voltage drops to 12.6v. If i put it in P or N, it goes back to 14v+. I installed a denso reman with an 34R odyssey AGM battery about 2 weeks ago.
The factory ground is on the inner fender right by the battery, I think.
adding ground wires is often an easy way to decrease electrical gremlins
i routed a larger wire from there to the - battery. i cant find the ground that goes from the engine to the body. I may just ground the alternator bolt to battery - as well.
There is a ground on the driver side in the harness and the passenger side over where the air intake goes through the fender, also part of the harness. You can run net new grounds in addition to these with no impact to function.
@Max Nguyen.
Aaah there is NO need to add a ground from the Alternator to the Battery negative.. the Alternator Body itself it a ground to the Engine.. So ensure your engine is grounded to the battery negative and the the Alternator body then is grounded to the battery via the engine...
