TreatSmash
Hey all, I am probably about to display some ignorance, I have read every thread in here that mentioned "alternator," "big 3," or "battery cables" and I still have some questions.
So I understand the big three are:
1. pos Battery to alternator
2. neg engine block to chassis
3. neg Battery to chassis
But the 2006 LC has:
1. neg battery to chassis
2. neg "hook on top of engine" to chassis
3. neg chassis cable into bundle to other "hook on top of engine"
4. neg battery to cable bundle running to back of engine
5. pos Alternator to fuse block (on battery) and fuse box (next to battery)
Okay so one at a time with pics and questions:
- I got this one
2. neg cable from hook on top of engine to chassis
- I replaced this one but, is this the "block to chassis" ground? Because it looks like a "hook on top of engine to chassis" ground. On the far left of this pic is top of the engine and on the right it is grounded to the top of the drivers side wheel well.
- Pretty sure this is good to go as well, I just replaced the existing cable.
3. neg cable into bundle to other hook on top of engine to chassis
- ok so is this one another "block to chassis" ground that looks like a "hook on top of engine to chassis" ground?
- This one runs down from chassis where I am pointing, into a cable bundle and then I am pretty sure it emerges on the other side and connects to the other hook on top of my engine.
- For this one I think I am just going tom run a second cable and leave the original because I won't be able to dig it out of the cable bundle.
- Is this the correct way to do this?
- of course I made it more difficult by installing my differential breather right on top of it, not know I would need to get at it later.
- ok so this one is where I get lost.
- The cable coming off the battery runs into a bundle that disappears behind the engine block. I cannot find where it terminates either by looking from the top or from the bottom of the vehicle.
- as you can see the cable is corroded and needs to be replaced, but I cannot even re-terminate it because there is no slack and it is too short.
- So where does this terminate? I assume the block somewhere?
- Is there somewhere else I can run a second cable and terminate it that will be as effective?
- any advice would be appreciated.
- I got this one
