Best remote start to add to daughter's 2019 4Runner? (1 Viewer)
Texas
I am sure there are ways to search this topic, but have never really had much luck with the search function. Looking to get her one for Christmas. Any help would be appreciated.
Push button or key start? If push button, there is a factory option from Toyota. If key start aftermarket only. There is a company called Accesorides that makes one I believe. Hope this helps.
It’s push button. Any idea if it’s plug and play, cost? Thanks!
I installed Accessorides..... It is like OEM, totally hidden, will run the engine for 10 minutes, and it will keep running even when you unlock the door. It is plug and play. I think it took me about 2 hours to install, but I really took my time to make sure that the tilt and telescoping steering worked well.
You push the lock button on the remote three times. When you unlock the truck you put the key in the ignition and turn it to the "on" position. If you touch the brake the truck turns off.
