Do you have a link to any studies done on the heat dissipation? I haven't ever been able to find any. Even Porsche admitted on their site a few years ago that the drilled/slotting were only for dissipating water vapors during wet track sessions, with no mention of the cooling effect. (This has since been taken down). I believe Stoptech had/has a similar article on their site.
The rotors are already vented, so I'm not sure if the holes really do much for cooling. If anything, it would be more prone to "warping" due to the material taken away (heat sink). This is why Toyota went to a much thicker rotor after complaints of rotors warping on the 1st Gen Tundras.
Cross-drilled rotors are good for fast heat dissipation and reduction in braking gasses, but they are more prone to warpage due to less rotor material/surface, and lower peak temperature tolerance before "warping". They are not ideal for longevity. A OEM rotor will cool and heat evenly during the braking stage, and cool evenly (which is what you want). Drilled/slotted rotors can have hot spots and cold spots after stopping and that will result in different pedal feel depending on driving conditions, etc. Drilled/Slotted rotors do reduce brake fade, but that is due to cooler operating temps.
It's a double edged sword to be honest. You want the rotors to maintain a reasonable temperature between two parameters, the peak temperature needs to be as high as possible, and it also needs to cool as quickly as possible. However we all know that heating and cooling metal quickly can cause warping. There really isn't a good answer for that question.
OEM is obviously going to be the most standardized option with the longest life and good performance, slotted drilled will give you a very "slight" edge on initial bite and immediate cooling, but you reduce the life and reduce the peak temp that the rotor can withstand before it "warps"
I am NO brake expert, I've raced for quite some time and have had my fair share of slotted rotors or not arguments. I've found that on the track, slotted/drilled perform slightly better when you are really romping on the car in the corners and under hard braking after the main straight (160MPH - 60MPH). However on the street, I see very little improvement over the OEM's (I have slotted/drilled). I do notice quite a bit more brake dust, and depending on how hard I have been driving the LC, different brake pressure and brake depression upon normal driving. For me driving the LC hard results in firmer brake pressure and less brake pedal input, slower driving, and cool rotors result in more brake input for the same stopping distance. If I had to do the brakes again on my truck, I would go back to OEM. Sure, the sporty rotors look great, but the only thing you are gaining on this type of truck is a thinner wallet due to added brake wear. If you really want to increase the braking power of the truck, you need to do a proper StopTech BBK like Spressomon has done. A simple bolt on aftermarket rotor kit with some pads won't net you much in terms of braking and reducing stopping distance. You need a lot more rotor and pad surface to make a difference on anything.
