Best Mods under $50... (23 Viewers)
Cutting the back off of the FJ and Installing military tarp over it with two bars to keep it up. Looks like a humvee
Unfortunately even with isolation between the aluminum tray and the steel frame, there is still likely a path for current to flow through the battery hold down clamp, which goes from the aluminum tray to the steel body.
I thought of that and put a rubber sleeve over the hook where it touches the tray.
My best mod under $50 to your battery tray... some nylon "T" washers where the steel comes in contact with the aluminum.
They don't absorb the vibrations as well as rubber washers. Come to think of it, I rejected the washers as too big and opted for smaller O rings.
If I say "Galvanic Corrosion" no one will know what the heck I am talking about. :flipoff2:
Nobody ever knows what I am talking about...:cheers:
Wrong. :) But if you start talking about Intergranular Corrosive Stress Theories you're going to loose me.
My latest under $50 mod:
1
Ebay sourced bag of 10 Marinco power point sockets.
if your blower fan doesn't work well, I just replaced the brushes on mine for about $5. Blows much harder now. Very pleased with the result.
What if the fan itself has a broken wing? Any cheap repair for that?
Better Radiator Petcock
I had the sorry plastic radiator petcock replaced with a metal one that I can attach a hose to when I drain the radiator. The petcock cost about $6 and the radiator man rethreaded the hole to NPT for a total cost of $35
I'm glad to see this thread still going strong after more than 4 years!
Still going under necessity!
Really like the petcock mod. I've always cursed the mess that comes with draining a radiator.
Quick Drain Engine Valve
One of my best mods by far (and under $30):
QuickOilDrainValve.com - the best way to change oil
Have had one on my Chevy K20 for years with no issues whatsoever, and makes simple maintenance all the more proper.
My LT1 likes its oil changes, and I dont mind not having to fight with a drain plug.
I read soemwhere on here moving the rear window sprayer to squirt on tail-gaters. I think that's an amazing idea, but on my 62 I have no idea how to even work that thing....:confused:
-Carl
-Carl
Hold the rear wiper switch down with you finger, about a second later, voila.
That only works if the fluid can make it to the sprayer . . . my hose is broke somewhere above my D Pillar . . . when I push the button it just dribbles down into my cargo area . . .
Thats my next fix
Mikesta, your very right 62's demand respect, if not already given, I just tap the brakes a little and they back off, but I want to know and somehow adjust it for my buddies that tailgate me in their trucks jsut to mess with me. And of course I do the same to then along with the occasional bump. :hillbilly::grinpimp:
So does anyone know how to adjust the sprayer to shoot backward?:cheers:
-Carl
May I respectively suggest that this sprayer discussion move off-thread? (and delete your off-topic messages)
This thread was meant to be a concise list of under $50 mods. Your question is interesting... just start a new thread in the 60 series tech forum....
(Not trying to be an a-hole here... just trying to keep this FAQ quality thread on track)
PS I will delete THIS message after it's usefulness has waned...
Mark you are totally a thread nazi and I fully support what you are trying to do in various threads. :flipoff2:
Talk to Woody about making you a mod. In the meantime, PLEASE just mods.
So in keeping on topic, tie in a vacuum gauge and mount it in the vehicle. This appears all over the forum but I don't remember seeing it on this thread.
The magnetic tool tray I referenced above, installed. Note, it will work through carpet, those magnets are strong.
Rear window sprayer hose fix
Thats my next fix
Mine didn't just dribble, it flooded. That cheap plastic aquarium-like plastic hose crystallized and broke just inside the rubber grommet and up under the headliner. I got 18 feet of rubber hose from NAPA with the same inner diameter of the broken plastic hose, but thicker sidewalls. After taking all the access panels off of the rear upper door and pulling the headliner loose about 18 inches from each back corner, I was able to finally get the rubber hose from the washer fluid bag through to the nozzle on the rear door by disconnecting the plastic tubing at the unions in the upper corners behind the head liner, attaching the rubber hose to the plastic tubing and pulling the rubber hose through. The only tricky parts were going through the rubber grommet between the body and the rear door (used spit for lubrication, but a little dishwashing detergent might have been more sanitary), and going down inside the rear drivers side post (right above the washer fluid bag). I started in the upper corner on the drivers side and went down to the washer bag. Once I got that, I connected the other end of the rubber hose onto the plastic tubing and pulled the hose across the back inside the framing just under the very back of the headliner. Then, through the rubber grommet, down the passengers side of the upper rear door, and then across the bottom of the upper rear door to the nozzle. Putting the headliner back, and all the trim pieces and panels back on, I now have a functioning rear window washer fed by a continuous rubber hose from the washer bag to the nozzle. It'll outlast the rest of the land cruiser.
