I saw the Valvoline Palladium 3% MoS2 at NAPA today.
<$3 a tube.
That'll be the stuff I use for my next repack (soon).
Hayes
<$3 a tube.
Hayes
I think I know where that recommendation came from. Did you order some Keystone too??
I think I got off on a tangent...I've been in the oil business for a little while now and these conversations always tickle me.
So what is your take on the use of a 5% blend over the 3%? I never heard of the moly causing wear. I however do understand that it can be though of an additive like graphite but it is not hard enough of a material to cause wear on hardened steel.
Moly is a solid that is ground up and put into oils or greases. Just like Bon Ami (non-abrasive cleaner like comet) says on its instructions "Never scratches..blah blah blah" then a warning that reads "Don't use on windows". Bon Ami has very non-abrasive cleaning agents in it, but it will scratch glass...ask me how I know.
Moly in the wrong situation can cause damage. Maybe not today or next month, but over the course of many hours of use it will eventually be visible to the naked eye.
If MOLY was the best there was, it would be in everything we use. Since it is an additive you could buy it by itself and add it to anything you wanted just like Honda did with their Pro-Honda HP-4M motorcycle oil. All they did was take their basic HP-4 oil and add a percentage of MOLY to it. That took the oil from a JASO MA rating to a JASO MB rating because the oil cooled/lubricated clutch slipped more with the MOLY present. In that application it could be very dangerous.
I will ask Threebond on monday if they sell their Molybdenum Dysulfide grease to Toyota since they are the predominate supplier of adhesives and greases to the Japanese engine makers. Once I know that, I will ask them what percentage it is the factory uses for Land Cruisers. I think I might already know, but I want to be sure (what I think it could be). Information changes to quickly to know anything for certain for too long.
I really hope some of this is helpful.
So are you sayin that the Aeroshell 33 (5% moly) that I just put in my 80 birfs at over $13 a tube is gonna wear them out!? DAMNIT, now I'm bummed!!!!
No, because the bearings that are being talked about are the wheel bearings, which do not come in contact with the birf grease (this will all make sense when you pull the axle apart). The knuckle (aka trunion) bearings are in the same area as the birf grease, and those bearings would get the same as the birf, they only turn when you turn the wheel, so not used in traditional bearing mode like a wheel bearing.Guess this is a dumb question but I'll ask anyways. If you are putting one of the Moly lubes in the Birfs, and a different synthetic type for the bearings, wont they end up mixing with eachother after heating up and churning ect? If this is the case, would there be a middle of the road lube to be used both in the Birfs and the bearings so mixing of different types will not cause premature breakdown? I don't know exactly how the axle are designed since I have not been inside mine yet but perhaps there are seals in place to keep the different types from mixing. I am getting ready to start my rebuild so this is a good thread for me since all I have left to get is the lube. Hopefully I can begin the rebuild this weekend.
