Hello Forum,
Looking for a little advice...
A guy reached out to me about working on his 2007 100 Series Land Cruiser w/ a bent valve.
Another shop just did the timing belt / water pump job and when they started it post job a valve (or valves...) was bent.
The other shop indicted that the issue was unrelated to the tb / wp job (very unlikely...).
The other shop is owned by a friend of his, so he's not pushing the issue.
I've done a lot of work on the 100 Series, including multiple timing belts.
From what I've read, the non-VVTi typically doesn't damage valves when a timing belt brakes.
Therefore, I would assume that a non-VVTi would not damage valves if a timing belt was installed incorrectly.
But, this is a VVTi motor.
If the timing belt was installed incorrectly, would it damage valves?
If so, how bad should I expect it to be?
Engine replacement time?
Pull heads and just replace some bent valves (and anything else damaged...)?
The motor has 230k on it and ran well prior to the tb / wp job (per the owner...).
Thank you in advance for your responses.
Tom
Tom
